XJ6 series 2 oil pressure
Hi everyone, just a quick question on oil pressure. My series 2 reads around 60 PSI @ 2000 rpm +, and 40 PSI idle around 750 rpm. However when I engage drive which reduces rpm to 450 / 500 rpm it goes to zero. Is this something to worry about or just a faulty sender ? The oil warning light does not illumintate at the same time. Many thanks.
I am using coolant temp and oil press sensors to match the Jag gauges that were purchased from Summit Racing. The gauges are working perfectly. Any parts house should be able to help you.
-OIL PRESS Sensor (gauge) C46272 for (JAG)
Dave
Dave
