XJ6 white/blue wire plugs into what terminal on the starter relay?
Old Jan 12, 2015 | 02:03 PM
Eurowerks's Avatar
Default XJ6 white/blue wire plugs into what terminal on the starter relay?
Any help is appreciated.
I have a 1980 XJ6 and I can't figure out on the wiring diagram where the white/blue wire plugs onto the starter relay....
Thanks in advance....
Adam
Old Jan 12, 2015 | 05:14 PM
Doug's Avatar
If you have a 4.2 you shouldn't need the white/blue. Was it ever hooked up? Did you trace it to see where it goes? It should just disappear in the harness and not connect to anything
If you have a 3.4 (with the old points type ignition) the white/blue goes to the same terminal as white/yellow (terminal C1) ....or a twin terminal to the white/yellow (terminal C4). Since the 3.4 uses a bypass resistor the white/blue is supposed to take 12v from the relay and send it to the coil "+" post when the starter is engaged.
Old Jan 12, 2015 | 05:42 PM
Eurowerks's Avatar
I believe it was connected to c1.
Bones
Sep 8, 2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
jaguarbill
Sep 5, 2015 11:43 AM
XJsc-guy
Sep 2, 2015 11:43 AM
