XJ6 Won't Start Today!
Old Mar 22, 2007 | 04:15 PM
Jose's Avatar
Default RE: XJ6 Won't Start Today!
not familiar with 1995 XJ but generic troubleshooting would be to check the obvious: is the car out of gasoline?? if ok, are there gasoline leaks or smells anywhere?? (open the trunk). Have you checked all Fuses? (the Owner's Manual will tell you where they are). Open the hood: Are the ignition wires properly in place?? (at the coil, at the spark plugs, at the ignition cap?).
more involved would be to make sure fuel is getting to the engine through the fuel injection system, and to check the fuel pump Relay. I don't think a fuel filter would cause it to not start, unless it was totally clogged and that just doesn't happen too often.
Take it to an independent Jaguar mechanic if all else fails to start it, ask them if they service the 1995 models, their hourly rate, if they try to sell you a Fuel Injection Cleaning Job, just say no.
good luck, let us know what was the problema.
Jose
JarodL
Mar 7, 2024 01:39 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
