causes for excessive fuel consumption?
Old Jun 3, 2014 | 11:31 AM
kpstealing's Avatar
Default causes for excessive fuel consumption?
What are some causes for excessive fuel consumption(avg.10mpg)
1991 xjs v12.?
New plugs,wires,fuel an air filters.
Old Jun 3, 2014 | 01:56 PM
Welcome to the forum Kp,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to XJS forum (the Advice / Feedback & Suggestion Center is only for posts about the forum). Members here with the same model will be able to help.
Old Jun 3, 2014 | 02:06 PM
Gunner01's Avatar
I'm interested in this as well, not terrible millage, but could be much better I believe.
Does the exhaust smell so bad of raw fuel on yours you can't stand behind in? That can't be a good sign!
Old Jun 4, 2014 | 08:39 AM
beefheart's Avatar
one thing i did was get rid if the cats on my 1985 xjs , i got better performance as well as better fuel mpg, also always use premiun fuel
Old Jun 4, 2014 | 02:17 PM
icsamerica's Avatar
Do you do a lot of short trips? The warm up cycle on the v12 requires a lot of fuel. Heating up 600lbs of metals, 8 quarts of oil and many gallons of water requires lots of energy. The initial high fuel consumption can really distort the average. I got about 8 mpg on my v12 sedan while doing mostly shorty city style running around.
Old Jun 4, 2014 | 05:21 PM
Doug's Avatar
Is that all 'city' driving, and you're not especially gentle on the throttle? If so, that's probably about right. Even with everything 100% and driven *gently* I wouldn't expect more than 12-13 mpg in all-city driving.
Steady speed highway driving should get you into the mid-to-high teens, though.
But to answer your question: a stuck enrichment switch, skewed coolant temp sensor, clogged cat convertor, broken/unplugged vacuum hose to the Marelli ECU, excessive fuel pressure, leaky pressure regulator, leaky injectors, dragging brakes......
That's off the top of my head
Old Jun 4, 2014 | 05:39 PM
Flint Ironstag's Avatar
If all else is good tune, a heavy foot in town will easily get you ~10mpg.
Seth
Nov 1, 2015 12:17 PM
XKE73EIconverter
Sep 26, 2015 10:21 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
DaveInVA
Sep 25, 2015 04:43 PM
reb1999
Sep 25, 2015 10:00 AM
