16/20 Radiator Caps - Quick Question
Old Jun 30, 2018 | 06:55 AM
Kariblay's Avatar
Default 16/20 Radiator Caps - Quick Question
Which radiator cap goes where?
I have a cap marked "16" and another "20". Does the "20" go on the radiator and the "16" on the reservoir?
Thanks....Karl
Old Jun 30, 2018 | 07:02 AM
Greg in France's Avatar
The 16psi goes on the wing header tank. This is what controls the entire system pressure. The 20 on there will over-pressure the system, but it probably does not matter.
The crosspipe spout cap, if you look at its overflow, vents into the radiator-top air purging pipe - which is itself still at the system pressure controlled by the wing header tank. So it does not affect system pressure if it lifts or not. In fact, a blanking cap is best on the spout, with no sprung inner! If no blanking cap, then I would use 16 psi in both. Which is what Jaguar did on later models, or eliminated the spout on the crosspipe altogether - but you need a header tank higher than the engine to do that.
Old Jun 30, 2018 | 07:20 AM
Kariblay's Avatar
Wing header tank = ?
Old Jun 30, 2018 | 08:46 AM
Doug's Avatar
Item #1 in this illustration, what you're calling the reservoir.:
https://www.jaguarclassicparts.com/u...ipes-5-3-litre
Old Jun 30, 2018 | 08:47 AM
baxtor's Avatar
front left hand corner of engine bay. Header tank also called expansion tank.
gagleisz
Jul 15, 2017 03:45 PM
Rideordie
Jun 8, 2017 10:25 AM
Spillwaybob
Oct 7, 2013 01:01 PM
