1977 XJS Power window issues.
Old Jun 18, 2019 | 04:48 AM
nudge61's Avatar
Default 1977 XJS Power window issues.
Hi all, can anyone help with the fuse and relay locations. I have no power to the switches. Any help would be appreciated.
Old Jun 18, 2019 | 07:45 AM
Welcome to the forums nudge61,
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
Old Jun 18, 2019 | 09:05 AM
leo_denmark's Avatar
There is a relay and some kind of fuse above the RH footwell, On my 1977 the issue was a broken hair wire in the relay.
Old Jun 18, 2019 | 07:17 PM
nudge61's Avatar
Thanks for that, I'll check it out.
Old Jun 19, 2019 | 05:14 AM
Bez74's Avatar
Hello Nudge
Being an Australian - it is on the left hand side - tucked in behind the glove box.
In regards to the picture below - please note that what I have labelled as circuit breakers are in fact bulb failure units
Mine was easy to get to because I have the dash fascia out to get the cracks fixed up and the air con repaired while it is out
No fuses in the system
Steve
Panel removed
Old Jun 19, 2019 | 05:28 AM
nudge61's Avatar
Thanks for that Steve, that's a huge help. I really appreciate it.
Old Jun 20, 2019 | 03:36 AM
nudge61's Avatar
Hi Steve, thanks for your info, I had a fried relay so I replaced it and all's good.
Nigel
mrincredible
May 3, 2020 03:09 PM
Gundawg
Jun 30, 2012 04:04 PM
GDadXJS12
Apr 3, 2012 10:28 AM
jp3872
Feb 17, 2012 05:01 PM
