1986 XJS Over heating
Old Jun 29, 2016 | 06:34 PM
that guy's Avatar
Originally Posted by orangeblossom
Hi Paul
Don't get too excited as if its been fill with that kind of stuff you might have to change all the Hoses.
Grant knows all about this, so I hope he will chime in and put you right.
Already taken care of, and it wasn't as difficult as I thought it was going to be.
Old Jun 29, 2016 | 06:35 PM
that guy's Avatar
Originally Posted by Lebonte
Thank you Doug, I'll try the fan clutch trick.
Thank you Mac Allan but I hope I don't need to replace radiator, but as the cliche goes, "It is what it is"
Beautiful XJS!
Old Jun 30, 2016 | 01:20 PM
Lebonte's Avatar
Thanks to all for your feedback here, suppose I'll tear her apart and see how the radiator looks...Yikes!
Old Jul 7, 2016 | 10:22 PM
Dr Quail's Avatar
The Lutz Stage 1 cooling system modification will solve a great deal of your problem along with the comments from DD and Grant. T-stats too short or semi-functional don't help.....Lutz Stage 1 mod moves the cooling flow to the back of the block as the system is basicallly lazy.....with the mod....
Norm Lutz calculated a new flow of something like 40%to the front where the Wtr. pump is located and 60% to the back where #s 5-6 cylindrs get hot (both sides), go into a shutdown heat soak and wait for that wonderful Ka-chinking of a dropped valve seat. When you do the mod. look for a 3/4 nylon bushing/ grommet from your friendly electrical supply or local hardware.....and insert in the T-stat casting at the bypass hole to provide an improved seal for the t-stat foot. The Lutz Stage 1 is simple and very straight forward to perform.....will attempt attache photos or PM me and I will send them to you. Best, JW I posted photos of the seals somewhere here on the XJ-S/V12 threads........very nice machine........drive it like you stole it once you get the cooling system sorted.
Old Jul 8, 2016 | 03:20 PM
Lebonte's Avatar
thanks Quail but I'm not mechanically inclined enough nor do I have all the tools to accomplish that feat. These V12' engines are complicated for a simpleton as myself.
Daim
Jul 2, 2016 08:04 AM
smartobject
Jun 29, 2016 07:45 AM
andyXJR
Jun 17, 2016 06:19 AM
mrplow58
Jun 16, 2016 04:05 AM
Bryan Fisher
Jun 11, 2016 07:06 AM
