1986 XJSC Starter Replace
Old Aug 4, 2025 | 02:23 PM
SeanC115's Avatar
Default 1986 XJSC Starter Replace
Hello! Hoping to get your collective wisdom on this one - I believe I need a new starter and I have sourced the parts needed.. In your opinion, is this a job that I can do in my garage with jackstands and regular tools, or do you recommend I find a shop that will do it?
Old Aug 4, 2025 | 02:49 PM
ptjs1's Avatar
SeanC115,
First of all, what car do you have? Is it a 5.3 or a 3.6? It makes a huge difference as to the degree of difficulty?
Also, what makes you think you need a new starter? Many of the problems that owners have with slow starters are more likely to be positive or earth connections, either at the starter or at the bulkhead of the car.
Paul
Old Aug 4, 2025 | 02:59 PM
SeanC115's Avatar
Hi Paul, thanks for the reply! I have the 5.3 and I believe it's the starter because it has been sounding like it's strggling for several months. Over the last week it began making a very slow almost grinding noise without being able to start the car. Now now it does not engage at all. I replaced the battery and it still will not engage. I'm definitely willing to try to troubleshoot other things first. Kind Regards - Sean
Old Aug 4, 2025 | 03:23 PM
ptjs1's Avatar
Sean,
Others, particularly Greg recently, have described the removal and replacement of the V12 starter motor. Read through the posts and you'll get a feel for the procedure and the difficulty involved.
It's definitely worth you disconnecting, cleaning and reseating the wiring connections at the starter motor and back to the bulkhead power and earth terminals. They are all prone to deterioration. It could save you a huge amount of money and effort, and just possibly, cure the issue.
Good luck
Paul
Old Aug 4, 2025 | 04:06 PM
Doug's Avatar
Yes. But you won't like it
I've done it that way, years ago. Not sure if I could do it nowadays with all my aching joints and bones! If you're under 60 you can probably do it . Under 50 might be better
In a very brief nutshell you'll have to drop the RH exhaust pipe and remove various heatshields (make a note of how they go back!). Use a long extension to reach the top bolt....which takes a 7/16 twelve point socket.
Others will have more detail
But, yes, make sure you really need to replace it first!
Blue340
Oct 30, 2024 02:23 PM
No Quarter
May 11, 2022 02:16 PM
dhatfield12
XJ40 ( XJ81 )
Sep 12, 2016 11:22 PM
jnporcello
Apr 22, 2015 04:04 PM
maikal_0011
Nov 5, 2011 11:18 AM
