1988 xjs v12 Been running AWESOME TILL
Old Nov 1, 2012 | 11:51 AM
Qgregg's Avatar
Default 1988 xjs v12 Been running AWESOME TILL
Yesterday transmission hose rubbed against pulley which caused much spraying leak,
fixed hose.----
Now iam not getting a charge from alternator.(which is brand new) figured liquid got on it and shorted something out. is there a fuse somewhere for the alternator. or u guys think my alternator is now fried??
Old Nov 1, 2012 | 02:01 PM
Per's Avatar
Per
Could also be a heavy residue of fluid on the slip rings / brushes. Measure the (battery) voltage at the alternator first. If OK take the alternator off and pull the brushes. If contaminated, use acetone on a cloth to clean the surroundings and then the slip rings by turning the pulley by hand. Change around the surface the rings see often. (If you have a compressor cover your face and GENTLY blow the area around the rings reasonably free of fluid first. I use a dust mask and then the automatic welding helmet for such jobs.) Then clean the brushes thoroughly.
mbergen
Oct 23, 2019 10:26 PM
Doug
Feb 27, 2019 01:31 AM
cissdm
May 3, 2016 06:02 AM
d a
Sep 3, 2015 02:34 AM
XJsc-guy
Sep 2, 2015 11:43 AM
