1991 Jaguar XJS V12, No Cranking After Driving
Old Apr 13, 2025 | 05:33 PM
Randyp's Avatar
Default 1991 Jaguar XJS V12, No Cranking After Driving
Hello, I have a weird one. I have a 91 XJS with a V12 I recently rebuilt and included a new gear reduction starter. The car was recomissioned after being parked for some years due to engine issues. The car runs great, but the problem I am having is the car does not crank/restart once it has been driven for a period of time. It always starts cold, but once driven for 20 or more miles, nothing, no click, dead. I originally thought it was the starter relay under the hood, but after swapping out about 4 of those, I realize now it must be something under the dash. I can start the car every time by pulling the hot and the starter wire off of the relay and arcing them together. The car cranks right over and starts immediately but it is rather annoying to pop the hood to start the car. As I recall, there is another relay under the dash somewhere that coud be defective, or the starter switch itself is defective. I don't believe the starter relay is receiving the start signal from the ignition switch/relay in the cabin. There is not even a click from the relay when I turn the key to start. Other work arounds are simply to install an override start button from the relay, but that is kind of a backyard fix. Thoughts? Thanks for your help.
Old Apr 13, 2025 | 06:09 PM
Doug's Avatar
Do you have a test light ? or voltmeter?
A couple preliminary checks
Next time you have a 'no crank' condition see if the white/yellow wire at the starter relay has 12v +"+ with the key turned to start. If not, suspect a problem with the ignition switch
Also check the the black/green wire at the starter relay is ground with the gearshift in P or N. if not, suspect a faulty or misadjusted neutral safety switch
Old Apr 14, 2025 | 09:44 AM
Randyp's Avatar
Default No Start
Thanks!
Old Apr 14, 2025 | 06:43 PM
orangeblossom's Avatar
Check out the Fuseable Link on the Battery Positive in The Boot Trunk (Its basically just a joiner with a Fuse that pushes together) so give it a good clean
The Fuseable Link can become disconnected just by looking at it! Often when changing the Battery
Or more likely got jolted apart on a drive out
Its almost on a 'Hair Trigger' and only require a small amount of movement to disconnect it and then when you turn the Key you get nothing! not even a 'Click' failing that try cleaning the Lug on the Self Starter
J_C_R
Oct 22, 2024 03:50 PM
XJS12
Jul 3, 2023 08:21 PM
lambo911
Jan 25, 2023 05:38 AM
N Bath
XJ XJ12 ( X305 )
34
Dec 3, 2022 06:44 PM
Rob Benjamin
Nov 7, 2020 01:27 AM
