1991 xjs v12 ff17 error code after changing Air Temperature Sensor
Old Nov 22, 2022 | 11:07 AM
dutkowsky's Avatar
Default 1991 xjs v12 ff17 error code after changing Air Temperature Sensor
After a Marelli meltdown, I had all of the fuel injectors rebuilt and calibrated, installed new coils, distributor cap, rotor, plug wires, and cleaned out the exhaust system on the A bank. When I started things up I had a rough idle. I changed the Coolant Temperature Sensor and there was a marked improvement in the idle smoothness.
I figured if the CTS helped the idle, changing the Air Temperature Sensor might be a good idea. I ordered a new Lucas ATS and installed it. Immediately on startup, I got an FF17 code. I cleared the code and got it again as soon as I started the car. I put the old ATS back in and no code issue.
Please help me to understand - was the new ATS defective or is there another issue that I should be looking for?
RacingGreen87
Mar 26, 2024 06:14 AM
ferrral
Aug 13, 2021 04:11 PM
mick99
Feb 1, 2016 10:51 AM
travis1215
XJ40 ( XJ81 )
May 16, 2008 02:34 PM
devic
Nov 21, 2007 10:54 AM
