XJ40 ( XJ81 ) 1986 - 1994
starting and running problems
Old Apr 19, 2008 | 09:59 PM
travis1215's Avatar
Default starting and running problems
Hello i just bought a 91 xj6 sovereign. When i bought it ran. Its been sitting for about 6 months now and got it started but has no power when you give it gas. It gave a code for fuel which was either to rich or lean so i replaced the fuel pump. That didnt work! It has a very strong odor of gas but will not start. I am going to do a simple tune up new plugs,wires,distruberter cap,and rotor. What else might cause it to do that.
Old Apr 19, 2008 | 10:03 PM
thisguy's Avatar
Default RE: starting and running problems
air flow meter, coolant temp sensor, oxy sensor or tps.
wich code came up ?
Old Apr 19, 2008 | 10:07 PM
travis1215's Avatar
It was a code fuel 12 or 14 cant remember which one but now it is a code fuel 69
Old Apr 21, 2008 | 05:36 AM
thisguy's Avatar
code 12 = air mas meter
code 14 = coolant sensor
code 69 = park/neutral switch
these codes are for the 4.0lt
Old May 13, 2008 | 12:08 PM
travis1215's Avatar
thanks for that info on the codes did a simple tune up and it starts and runs now idles great all the way till it is completely warmed up then give it gas and it wants to die you can feather the gas and try and keep it running but adventually it dies. Starts right back up idles fine for a minute the starts to die again. There is no code's to read so i am stumped on it.
Old May 13, 2008 | 10:17 PM
JagtechOhio's Avatar
Put a fuel pressure gauge on it and see what's up.
Old May 14, 2008 | 08:25 AM
ken@britishparts.com's Avatar
Just thinking out loud. What about a crack in the air intake bellows. Wouldn't a large air leak cause this same thing? Or, a stepper motor stuck wide open? Just ideas.
Old May 16, 2008 | 02:34 PM
travis1215's Avatar
ok new post here i did some test on it which envole checking the maf and the ecs. the maf checks out with 2 volts for a simulated load but only has 2 volts for the ref volt to ecu. the ecs is checking aroun 416 ohms at normal running engine temp. so my question is do both of them need replaced or are they within working tolerence. because the ref voltage is suppose to be 5 and ohms is suppose to be from 200 to 350 ohms. And i was off on my descripsion of what is the problem. idles fine give it gas fast nothing just stalls. give it gas slowly and it reves up fine.
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
1964Daimler
Sep 2, 2015 11:41 PM
nelsonht
Aug 30, 2015 06:01 AM
Jandreu
Aug 29, 2015 07:31 PM
