XJ40 ( XJ81 ) 1986 - 1994
not staying running
Old May 11, 2008 | 02:05 PM
travis1215's Avatar
Default not staying running
i have a 91 xj6 sov it starts fine and idles fine but after it warms up completely it begins to spit and sputter and if you give it gas it just dies then you left off the gas it comes back to idle then begins to spit and sputter again till it dies any ideas. It has a new fuelpump,fuel filter new plugs and it doesnt give me any codes to read at all.
Old May 12, 2008 | 01:01 PM
ken@britishparts.com's Avatar
Default RE: not staying running
Try a temp sensor for the fuel injection. It's an inexpensive guess and common failure.
Old May 13, 2008 | 12:10 PM
travis1215's Avatar
thanks for the guess on that but where would that be located at so that i can give it a check
Old May 13, 2008 | 04:11 PM
It's in the thermostat housing. Has two blades in the connector.
Old May 13, 2008 | 04:37 PM
FactoryJaguarTech's Avatar
Idle control valve maybe? I would start with the sensor. I am not up on the older vehicles. Spend all my time in the newest ones back....so never make it back further than 97 really.
There are some knowledgable folks here with regards to the older cars.....good luck.
Old May 16, 2008 | 02:37 PM
travis1215's Avatar
ok new post here i did some test on it which envole checking the maf and the ecs. the maf checks out with 2 volts for a simulated load but only has 2 volts for the ref volt to ecu. the ecs is checking aroun 416 ohms at normal running engine temp. so my question is do both of them need replaced or are they within working tolerence. because the ref voltage is suppose to be 5 and ohms is suppose to be from 200 to 350 ohms. And i was off on my descripsion of what is the problem. idles fine give it gas fast nothing just stalls. give it gas slowly and it reves up fine.
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
trosty
26
Dec 18, 2022 06:40 PM
Jpav27
Jul 31, 2022 06:43 AM
kevo
Sep 8, 2015 09:45 AM
