1992 XJS v12 won't start
Old Aug 24, 2020 | 08:59 AM
Brett Middendorf's Avatar
Exclamation 1992 XJS v12 won't start
I drove my jag about 100 miles on Saturday. Everything worked great and she's been running great for the past month always starting without hesitation. I went to start up the car on Sunday and it won't go. The starter works, battery is strong, plenty of gas but for some reason - it just won't start. Any suggestions as to where I should start?
Thanks!
Old Aug 24, 2020 | 09:16 AM
garethashenden's Avatar
Does plenty of gas mean the tank has gas or that you're getting gas to the engine? I'd be tempted to disconnect a fuel hose and pump some gas into a suitable container to check. If you are getting gas then check the spark. If you have both fuel and spark then it should start.
Old Aug 24, 2020 | 10:17 AM
Xjeffs's Avatar
Default Air, spark, fuel
I always start with the 3 components of combustion. When you let on without cranking, do you hear the fuel pump kick on for a couple seconds? This tells you the ECU is alive and the fuel rail is probably charged.
if you have a timing light, you can clamp it around a spark plug wire to see if you have spark.
Do you have any codes?
Old Aug 24, 2020 | 11:17 AM
Mac Allan's Avatar
Read this:
https://www.jaguarforums.com/forum/x...he-v12-178286/
Good luck.
delo
Jul 18, 2018 05:27 AM
Kariblay
Jun 29, 2018 02:55 PM
Pudjob
Nov 14, 2015 12:30 PM
savbolo
Apr 27, 2011 03:29 PM
jon s
Jan 20, 2011 04:12 PM
