1993 XJS 4.0L belt replacement
Old Dec 15, 2012 | 03:31 PM
scrible's Avatar
Default 1993 XJS 4.0L belt replacement
I am in need of changing the air pump v-belt on my 1993 XJS 4.0L. I haven't torn it down yet but it appears that the air pump belt is too small to be removed with the clutch fan in place. Does it need to be removed or is there a trick to replacing it or "working" it off of the clutch fan?
All help and ideas are appreciated.
Thanks!
Old Dec 23, 2012 | 12:21 AM
scrible's Avatar
Nobody? Come on guys!
Old Dec 23, 2012 | 09:20 AM
Roger95's Avatar
You should be able to easily maneuver that belt around and up and over the fan.
It may not look longer enough but it is can be removed over the fan; if t is similar to the alternator/WP belt.
You don't have the electric air pump?
Old Dec 24, 2012 | 05:36 AM
mrtalkradio's Avatar
If you are replacing one, replace them all. There are 4 I believe. You can keep the fan on. Have patience, especially when doing the power steering belt. 15mm wrenchs. Ratchet Wrenchs are the ideal tool for this job. You'll need a 15mm stuby for the PS.
Old Dec 24, 2012 | 04:53 PM
Steve M's Avatar
I know that I am going to sound a bit dim here, especially as I am on my 4th XJS, but which bit is the air pump and what does it do?
I assume that simple transatlantic wordage changes may be part of the problem (wing/fender, sump/pan, boot/trunk) but I have been scratching my head/**** for ages now wondering what the hell an air pump does (yeah, I know, it pumps air smarty pants) and why would you want one?
Old Dec 25, 2012 | 08:16 AM
Roger95's Avatar
The air pump is only a polution/emisions control device. It does its duty by pumping additional air into the exhaust gases before the cat cons.
Old Dec 25, 2012 | 02:43 PM
Steve M's Avatar
Ok, thanks.
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
