1995 XJS Remote/Key Fob Programming?
Old Feb 9, 2012 | 09:45 PM
N14ParkwayRacer's Avatar
Default 1995 XJS Remote/Key Fob Programming?
I was wondering if I could by a used remote for my XJS keyless entry & program it to work for my car. I've seen them on Ebay for about $50. My car only came with one key & no fobs when I bought it. Any help would be appreciated. Thanks.
Old Feb 14, 2012 | 07:43 AM
xjrguy's Avatar
Yes, you can buy a remote to use with your car. However, there is no manual programming method for the '95 XJS, it will have to be programmed with the Jaguar dealer equipment.
You need part number DBC10084, DBC100841 or DBC100842, they all are identical.
Cheers,
Old Feb 14, 2012 | 03:50 PM
Spikepaga's Avatar
I have programmed 3 remotes on my 95. It is most certainly possible. You just have to undo the console and find the place where the valet switch would have gone, cut the connector out from the wires and connect each wire to each end of the toggle switch and you have a valet switch
Old Feb 14, 2012 | 10:56 PM
Vee's Avatar
Vee
I have done it too, on my '96. You have to make sure you get the FOBs with the right MHz frequency. I believe you will find most in the 433MHz. You are only interested in the 318MHz. The other one will not work.
In my experience you can find a great, like new looking 433MHz FOB for around $50. You will not find the 318MHz so easily at that price. Be wary of used FOBs, they're usually pretty roughed up. They're going to look like they're 15 years old, because they are.
You can also go aftermarket for a lot less. I only got one FOB with my car, so the spare has an aftermarket. Doesn't look as good, but has a better range.
Do a search on my posts and you'll find a step by step procedure for programming a new FOB for your existing system.
Jaguar_libra
Sep 10, 2015 11:05 AM
Jaguar_libra
US Western
Sep 9, 2015 04:20 PM
Rick Michael
Sep 6, 2015 06:53 PM
My Pham
Sep 4, 2015 03:37 PM
d a
Sep 3, 2015 02:34 AM
