1995 XJS Wheels
Just bought the 1995 XJS droptop, and it has 15" wheels. I am considering replacing them with a larger size. Does anyone have any recommendations, and what differences can i expect with the larger rims? Thanks for any insight.
Yikes, 15", that's like a yugo size wheel!
Do some research online, there are a plenty of other XJ (and some XK8) wheels that will fit your car, just need to make sure the bolt pattern is the same and width is close (+ or - 0.5" probably ok). If you stick with years generally around yours, you'll have less change of goofing up the offset. Find a couple you like that have a the same bolt pattern, post up pictures, and we'll confirm for you if they will fit the other ways.
good luck, shopping for wheels are fun!
Do some research online, there are a plenty of other XJ (and some XK8) wheels that will fit your car, just need to make sure the bolt pattern is the same and width is close (+ or - 0.5" probably ok). If you stick with years generally around yours, you'll have less change of goofing up the offset. Find a couple you like that have a the same bolt pattern, post up pictures, and we'll confirm for you if they will fit the other ways. good luck, shopping for wheels are fun!
metalmarty
Sep 11, 2015 07:05 AM
