1996 XJS stuck in Park
Old Sep 17, 2014 | 07:15 PM
snowball's Avatar
Default 1996 XJS stuck in Park
Have had trouble starting my 1996 XJS AJ16 4 litre in Park and always start it in Neutral, will rebuild or replace rotary switch on tranny this winter, but today transmission stuck in Park. I can't get out of Park, is this the rotary switch or something else?
Snowball
Old Sep 18, 2014 | 01:43 AM
barmorehome's Avatar
Can't speak to the starting problem, but you can get out of park by removing the gearshift cover (two small screws) and carefully setting the brush aside, and then -- to the left of the shifter is a hole that you can put down a small flat screwdriver or the gas cap key.
At least that's what I did and the problem has not returned.
Old Sep 18, 2014 | 01:23 PM
Bill C's Avatar
barmorehome is correct about using the lock bypass to get your car out of Park, but that won't solve the problem. I also had the same issue, and the problem lies in the Brake Light Switch.
I've attached a file which may be of some help.
File Type: pdf
Old Sep 18, 2014 | 01:59 PM
snowball's Avatar
Just an update. Had it for a good run before this happen, after checking every fuse and looking at relays, low low battery. Thanks for the help.
Snowball
Old Sep 19, 2014 | 07:22 PM
RagJag's Avatar
Mine did that too. I removed the gadget at the gear shift so it couldn't ever do that again.
RagJag
kevinl
Oct 31, 2019 06:15 PM
Rlover
Mar 30, 2016 10:04 PM
neruda
Oct 18, 2015 01:19 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
