1996 XJS Tachometer issue
Old Aug 19, 2010 | 09:35 PM
El Gato's Avatar
Default 1996 XJS Tachometer issue
My 1996 XJS - 6 cyl convertible has a tach that cuts out intermittently. The speedometer, odometer and trip meter work fine so I'm thinking the sensor module is ok ( I understand the tach, speedo and odometer are linked to the same sending unit / module ) and it's simply a dirty or loose connection behind the dash (yes I am an optimist).
Once I drop the lower panel under the dash on the drivers side, does anyone know if Ill be able to actually reach the wiring to check / clean the contact points or should I attack it from another direction? Or maybe someone else has encountered this?
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
XJsc-guy
Sep 2, 2015 11:43 AM
