6.0 block drain?
Old Mar 12, 2026 | 01:27 PM
Jagboi64's Avatar
Default 6.0 block drain?
I'm wanting to do a complete drain and flush of my cooling system, and I was wondering if there is a drain for the block? I can tell there is still coolant in there, so I wanted to get that old coolant out.
Part of the reason is I still had the old green style coolant in there, and I was going to change coolant type, so didn't want to mix colours of coolant.
Old Mar 13, 2026 | 04:48 PM
Tyee's Avatar
Not sure about the 6.0 but if there is any drain plugs on the 5.3, I couldn't find them. I pulled the rad and water pump when I did ours, jacking up the back of the car got most of the coolant out of the block. With it still jacked up I ran the garden hose into each side of the block and flushed out the remainder of the coolant. After adding 50/50 pre mix, my tester shows the concentration still at 50% so there couldn't have been much water left in the block.
garethashenden
May 4, 2025 08:01 AM
SeanU
Jun 23, 2024 04:57 PM
‘Oleguy
Nov 2, 2023 11:40 PM
chillyp
Jul 4, 2022 07:46 PM
MrAndersonGCC
Jan 4, 2022 10:13 AM
