86XJS COUPE Dana oil change, need help.
Old Oct 12, 2010 | 02:15 PM
JayDeBee's Avatar
Default 86XJS COUPE Dana oil change, need help.
Have just replaced discs and shocks and before replacing crossmember I thought it might be prudent to change the oil. Since the Dana rear end has friction clutches, I am not sure what oil I should put in there and if any additives are required. Is Red Line 75/90GL-5 OK and would I need to add friction modifier to this?
Thanks in advance for any suggestions.
Old Oct 12, 2010 | 06:35 PM
Doug's Avatar
I use regular gear oil with the GM 1052358 friction modifier. Not sure if the Red Line stuff already has a friction modifier....some gear lubes do.
ZJag
26
Sep 5, 2016 03:33 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Jag-o-nomic
Sep 4, 2015 03:07 AM
David Thompson
Sep 3, 2015 07:48 PM
pnwrs2000
Sep 3, 2015 11:55 AM
