87 XJS shockie replacement
Old Mar 20, 2019 | 05:24 PM
AnD3rew's Avatar
Default 87 XJS shockie replacement
Any reason I would need to go to a jag specialist for this or is any suspension place ok? And what do you recommend. I think the originals are Bilstein do I go with that?
Old Mar 20, 2019 | 07:28 PM
EcbJag's Avatar
The original shocks are Boge and are still available. Bilsteins will work but they were a little too stiff for my taste when I installed them on my dad's xj-s several years back just fyi. It's an easy DIY job. The front ones are especially easy as they are independent from the coil spring. The rear is a little tougher since there are 4 and you must compress the coil springs. I don't see how any independent shop could mess it up.
Old Mar 21, 2019 | 04:38 AM
VancouverXJ6's Avatar
KYB Grey shocks work well, I ordered from rockauto. Not rock hard but enough to give the car a smooth ride while still allowing for extremely nimble maneuvering. If looking into suspension also assess the bushings all around, jacking the car up and letting it hang will give you a good idea. While redoing my suspension with KYB shocks along with superflex poly bushings/subframe mounts a number of failing bushings and mounts were discovered which contributed to steering jutter, and sloppy handling.
davetibbs
May 29, 2024 02:06 AM
silverkat
Oct 11, 2015 09:11 AM
sjgh
Jul 31, 2013 08:25 AM
expedio2005
Nov 19, 2010 09:28 AM
hopeitworks
Jun 23, 2010 11:21 AM
