88 xjs installed LED strip behind cluster
Old Feb 11, 2016 | 06:02 PM
Qgregg's Avatar
Default 88 xjs installed LED strip behind cluster
Got these strips off ebay 4.00 us. Not bad so far. Still not in the car yet these pic are outside hooked to a battery.
Better than the old green bulbs
Not bad
I can see
Even this one is better than original
Old Feb 11, 2016 | 07:05 PM
JagZilla's Avatar
Looks like better illumination than the original setup.
Are they blue LEDs, or, is that just the way they showed up in the pix?
If they are blue, do they offer clear, and, other colors?
Can you give us a link to the ebay listing, so we can see how they look?
Old Feb 11, 2016 | 07:22 PM
Qgregg's Avatar
Default http://m.ebay.com/itm/181793960521?euid=5a8d0f213cec4a48894c62f24cb1b5aa &_mwBanner=1
led strip
Self adhesive backing
Drilled small holes
Will probally insert wires with existing bulbs to add to circuit positive negative
Old Feb 11, 2016 | 07:25 PM
Qgregg's Avatar
Default Led strip
Forgot to add not sure what other colors they have. And yes these are blue............
Originally Posted by Qgregg
led strip
Drilled small holes
Old Feb 11, 2016 | 09:23 PM
BC XJS's Avatar
Great out of the box thinking.
I used 4 led strips (white) in my trunk and the illumination is great. Plus if the trunk is open it won't drain the battery. I've ordered more for the interior and under the hood. Bonnet for those across the pond.
