90 XJS Won’t Start
Old Jun 16, 2018 | 02:43 PM
Kariblay's Avatar
Originally Posted by orangeblossom
Hi Kariblay
If She was running Ok before you got water in her, then I really can't see anything else that it could be and maybe it hasn't had a chance to dry itself off properly
The only quick fix that I can suggest is to disconnect those plugs where they push together and them give them a blast of Warm Air from a hand held Hair Dryer
Could it be a bad fuel filter or pump? It just doesn't sound like it's getting any fuel...before when I had the "wet" problem I could smell gas when I depressed the gas pedal - i don't smell any gas.
Old Jun 16, 2018 | 04:44 PM
orangeblossom's Avatar
Hi Kariblay
There is a very long list of things that it could be and if you cannot hear the Fuel Pump run then it 'Could' be that
Bear in mind that the Fuel Pump only runs for 3 Seconds every time you turn the Key (on and off)
So try that first and let us know if you can hear the Fuel Pump run or not
Old Jun 19, 2018 | 09:11 AM
Kariblay's Avatar
Diagnosed as faulty Air Temperature Sensor.
Old Jun 19, 2018 | 09:19 AM
Well done problem solved then
Old Jun 29, 2018 | 02:55 PM
Kariblay's Avatar
Smile
Ok...after a few cleansing breaths...changed out the air temp sensor, front crank sensor, fuel filter and pump...now she starts better than ever and so far, all is well.
Keeping my fingers crossed!
avt007
Nov 1, 2015 06:45 PM
Bcxman
Aug 3, 2015 09:53 PM
GT42R
Jul 6, 2012 06:44 PM
monkamah
Aug 29, 2008 06:23 AM
