91 XJS convertible window question..
Old Jul 26, 2015 | 05:27 PM
Alexv12's Avatar
Default 91 XJS convertible window question..
Hey guys this is my first post here. I have been trying to fix up a 91 xjs v12 convertible, and have encountered one of my first issues. So here is the deal...
I was driving with the top down and pulled in to a car wash to give the car it's first cleaning in my hands. Put the top up and locked it down. Put the windows up.... So far so good. Open the drivers door and get out and proceed to close the door. I noticed it wasn't shutting well and I could actually see in the car through the side, no good since I am about to go at it with a pressure washer. The window was hitting the convertible top on the top and also sitting too far to the right and hitting the quarter panel as well. However from the inside, the window would go up and seal properly, the problem arised when I would get out and go to close it again.
Let me know if you guys have encountered this before. I am reading up on THE BOOK as well.
Thanks all!
Old Jul 27, 2015 | 02:30 AM
ptjs1's Avatar
There's a section in the jaguar workshop manual on aligning the front and rear Windows. It's a bit fiddly but worth it. If the front window is fouling the hood when you shut the door, it sounds like window alignment settings (assuming the hood is closing ok)
Good luck
Paul
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
XJsc-guy
Nov 23, 2015 01:56 PM
sadepol01
Sep 11, 2015 05:26 AM
