92 XJS convertible ATF
With 53k miles on my 92 XJS, V12 I'm thinking of having the ATF flushed and a new filter and gasket installed. I believe Dexron 111 is the correct fluid. Any hints on sourcing the correct filter and gasket?
Stephen
Stephen
First of all, I recommend going through the small effort of completing the auto signature feature on this forum. You'll never forget to clarify this info again.
Secondly, I didn't think that the v12 guys had any trouble sourcing common parts like transmission filters. What transmission are you using? TH400? Many websites, like RockAuto, specify which transmission they are for.
Hopefully someone else can chime in and let you know if there are any special o-rings or other parts that you will want to have on hand.
Ultimately, the transmission you have is likely not unique to Jaguar in any way, so part availability should be plentiful and affordable.
New Aceomatic Automatic Transmission Filter Jaguar XJS XJ12 1973 1979 1981 1992 | eBay
this worked for me
and the previous owner had mine flushed... (documented )
this worked for me
MK2
Oct 30, 2016 04:48 PM
flyinlow
Sep 25, 2016 05:08 PM
Matthew Chidester
Sep 25, 2016 10:43 AM
MrSlappy
Sep 23, 2016 08:44 AM
