93 4.0 FF codes help
Old Jun 14, 2021 | 04:09 PM
92/93 XJS's Avatar
Default 93 4.0 FF codes help
Are the FF codes the same for 6 and 12 cyl cars? I have the wrong owner's manual, showing V12 info. Is there a list online of 4.0 codes if they are in fact different? Anyone have a lead on the correct original owner's manual to buy?
Many thx to everyone!
Old Jun 14, 2021 | 04:18 PM
OldCoastie's Avatar
Sent you a PM
Old Jun 14, 2021 | 10:33 PM
92/93 XJS's Avatar
No PM came thru
Old Jun 14, 2021 | 11:33 PM
Brewtech's Avatar
FF39?
typically the EGR valve is losing vacuum somewhere. The plumbing at the lower portion of the throttle body gets plugged up by oil.
Old Jun 19, 2021 | 06:56 PM
92/93 XJS's Avatar
FF39 has never popped. I get FF17, 23 and 26 regularly. 2 of the 3 seem to be "air leaks", so today I took apart the entire assy of air filter can to throttle body. Found both the plastic, curved housing going into the rubber bellows and the bellows itself totally ruined. Someone had tried a real backyard fix on the plastic piece-to-bellows broken and filled with a weird, black "sealant" and the bellows had rips where the sealant stuck to it! Found good used plastic piece on Ebay and new bellows as well.
When new parts installed, should I expect a change in mileage and engine performance? Comments appreciated...
Julia Cameron
22
Mar 1, 2021 10:20 PM
95 AJ16-5
Oct 9, 2015 03:46 PM
giandanielxk8
Jan 14, 2014 02:22 AM
WaterDragon
Oct 11, 2012 01:55 PM
The World Tour
Jan 9, 2012 01:35 PM
