93 XJ-S 4.0 Conv.
Old Apr 7, 2015 | 09:45 AM
butkusandbale's Avatar
Default 93 XJ-S 4.0 Conv.
Hi,I just brought home our 93 XJ-S 4.0 Conv. from a 10 year storage garage in Georgia,it has 44k miles on it. All Original / Excellent Condition. *** Problem : When the battery is connected the car beeps...also head/side lights flash until vehicle is started. Then all is fine... Shut off vehicle ,then it beeps/lights again...until battery is disconnected or restarted ????? The only bulb that i found that is out,is the right front fog light,now on order. Any Helpful Info??? Thanks!
Old Apr 7, 2015 | 05:30 PM
orangeblossom's Avatar
Going by your description, it doesn't seem like you have a problem at all, as all the 'beeping' and flashing of lights, seems to point to the Alarm Immobilizer, doing exactly what it's designed to do.
The same sort of thing always happens on my Car, as if you are not sat on the seat with the key in the ignition, within about 30 seconds all hell breaks loose.
Which is an absolute PIA when you call in a Garage to buy Petrol and you are either putting your Wallet away or fumbling for the keys.
That's my Theory anyway, though no doubt someone else may jump in, with another solution.
Old Apr 8, 2015 | 07:42 AM
malc4d's Avatar
Sounds like you need to program the remotes. Does it beep 5 time when you reconnect the battery ? If you have all the handbooks read the one for the alarm.
Old Apr 8, 2015 | 09:25 AM
kurtomatic's Avatar
Your security ECU is upset about something. If your keyless remote is in good working order, then you may be able to fix this normally by resetting the remote as suggested. It sounds like this car is well preserved, so hopefully that's all you need to do.
If your remote is missing, dead, or worn out, then getting the security system under control can be a tricky and frustrating experience. There have been a number of threads in the past regarding this (such as this one), so searching the forums can help.
In the worst-case scenario, or if you just need to stop the blinking to buy you some time, you can simply unplug the security ECU. Your keyless access and other advanced security functions will obviously not work, but the car will start and run normally and the battery won't run down or have to be disconnected. I posted a pic of the block connector for the ECU in the linked thread above.
Good luck!
Old Apr 8, 2015 | 10:10 AM
Remote Alarm Fixed . All Good ! Thanks.
Old Apr 8, 2015 | 10:13 AM
All Good. Thanks !!!
sadepol01
16
Nov 22, 2024 05:05 PM
aode06
Jul 28, 2023 02:26 PM
SCMike
Nov 25, 2015 07:55 AM
mat32essex
Oct 3, 2015 04:12 PM
