94 xjs L6 engine,no start
Hi,my 94 xjs L6 engine will not start.Checked for spark,no spark.Checked coil (+) hot post with key on and it is only getting 7 volts from ignition key wiring.Checked coil (-) negative post with key on and it has 7 volts also.I imagine the problem to be coming from the ignition (key) wiring.When I try to start car,starter turns over good. There is no voltage reading when meter cables are attached to coil (+) positive post and coil (-) negative post while cracking engine.Hope there is somebody out there that can help me solve this problem.Thanks,HarryK
FS[SouthEast]: Books - Various Jaguar Titles
SCMike
Nov 25, 2015 07:55 AM
