96 XJS throttle problem
Old Mar 23, 2021 | 10:22 AM
Charles Treichel's Avatar
Default 96 XJS throttle problem
The engine idles normally when in neutral (automatic transmission) When shifting into Drive, it speeds up a little, going about 10MPH with foot off the gas. Looking for advice.
Old Mar 23, 2021 | 10:25 AM
clubairth1's Avatar
Community Influencer
Charles this is the wrong forum?
Maybe the mods can move your post?
Old Mar 23, 2021 | 09:26 PM
Vee's Avatar
Vee
You may need your TPS reset. It can only be performed by a Jag dealer or a device loaded with jag-specific software.
It’s plausible that you might only need a throttle body cleaning. It’s easy to do and cheap!
Old Mar 24, 2021 | 02:04 PM
equiprx's Avatar
I thought that normal RPM in neutral was lower than in gear.
That's the way I remember it.
Old Mar 24, 2021 | 02:11 PM
Vee's Avatar
Vee
No.
In gear, warm, the RPMs should be at 580rpm.
In Neutral, or Park, the RPMs are around 700rpm.
I would take a few hours and remove the throttle body. You need a 10mm socket to remove the four bolts holding it on to the intake manifold. It looks like there should be a gasket at the metal to metal connection, I can assure you there isn't.
Watch for the small coolant hose connecting in and out of the underside of the throttle body. A golf tee works well to block it up. The rest is pretty straightforward. You'll be surprised at how much gunk you have on both sides of the butterfly. Carb cleaner and rags. Should take you two hours, all in. Three tops.
dstary
Sep 19, 2020 05:55 AM
1199greg
Jul 30, 2013 07:11 AM
benzjag
Mar 21, 2013 02:19 PM
Vee
Oct 16, 2012 09:07 AM
martyorourke
Oct 29, 2007 10:43 AM
