ABS accumulator sphere
Old Aug 29, 2016 | 05:23 AM
Asdrewq's Avatar
Default ABS accumulator sphere
I think my brake accumulator needs replacing.
If I touch the pedal with the ignition on, the red/amber lights immediately light up and I can hear the pump engage. The pump also engages for around 0.5 seconds every 30 seconds with the ignition left on. . Sound to me like the is no pressure in the system at all.
Has anyone replaced it/have any tips?
I see that Jaguar Heritage sell them, but quite expensive at £177. Is anyone aware of an alternative supplier? I'm assuming Jaguar don't manufacture them...
Old Aug 29, 2016 | 08:25 AM
bigpigpants's Avatar
The part number of the item you want is: 25528382
Some time ago they were very cheap on Amazon but they are now long gone. The cheapest I can see on Amazon or EBay now is $195 + shipping & import charges from the USA - at current exchange rates, that makes Jaguar's £177 pretty reasonable if it includes vat. Whilst you're at it, I would replace the pressure switch as well. The part number for the one I bought, again from Amazon is: 25530882
Rgds.
Andy.
Old Aug 29, 2016 | 08:37 AM
Asdrewq's Avatar
Excellent info, thanks!
Is the pressure switch easy to change?
A bit of searching has yielded the following alternative p/n's for the accumulator ball; looks like there are a few late 80's cars which use the same ABS system:
lemforder 11797 01
Delco 25528382
Saab 4002267
Old Aug 29, 2016 | 11:49 AM
Jagboi64's Avatar
There are different sizes of ball and different threads, make sure it matches. BMW used a similar system, but it's a different thread size.
I've not really come across a decent source, I have picked up some used ones from the junkyard when I see them.
Old Aug 29, 2016 | 02:33 PM
AFAIK, it is easier to remove the pump assembly & hold it in a vice to use an Allen key to remove the accumulator - with the assembly in a vice it should be easy with the appropriate size spanner to unscrew the pressure switch & screw in a replacement.
Rgds.
Andy.
Old Aug 29, 2016 | 03:13 PM
Jagboi64's Avatar
Make sure the system is depressurized first before undoing any brake connections. It's different to most brake systems, there are specific instructions in the manual on how to do it.
scottpeterd
Apr 4, 2016 10:48 PM
innzane
Apr 3, 2016 08:43 PM
JohnBurns
Feb 10, 2011 11:51 AM
Audio/Visual Electronics
Jul 5, 2010 02:25 PM
Jan 7, 2008 09:43 AM
