ABS front brake sensors
Old May 28, 2023 | 06:49 AM
maccasa's Avatar
Default ABS front brake sensors
1989 XJS 3.6 Coupe (uk model)
I am having problems with ABS light on after replacing TEVES MK111 unit. Brakes are now fine. Having checked the front brake assembly I see there is a bulge in the wire going to the brake sensor and looks like someone has reconnected the wire at some stage. I also found the cover was missing on the ABS ECU blink test sensor. I want to replace the sensor but fond they are not available from the usual Barrat/Manners source. Anyone know ehere I can get one (that works)
Old Aug 27, 2023 | 05:38 AM
kevinphall's Avatar
Hi Maccasa,
Did you manage to find a replacement sensor?
I’m having the same problem. Looking for both front ABS sensors for 1988 XJS 5.3 and can’t seem to find new ones anywhere.
Would appreciate any leads you may have found.
Thanks.
Old Aug 31, 2023 | 11:32 AM
wolf_walker's Avatar
Last time I saw new ones they were "cost prohibitive", in the $500 usd range and I think those were aftermarket.
Might be best to hunt for a second hand one or repair what you've got.
Standard Motor Products still lists the fronts and one rear, don't know if they are actually available anywhere.
https://ecatalog.smpcorp.com
Uk5speed awd
Dec 25, 2022 06:17 AM
Mozambique
Oct 11, 2022 04:44 PM
Aincite
Sep 18, 2019 08:25 AM
Robert Laughton
Oct 4, 2018 03:59 AM
cybercg
Sep 18, 2012 08:26 AM
