Ac controls / wiring diagrams 1996 xjs
Old Feb 21, 2019 | 12:48 PM
louiedog's Avatar
Default Ac controls / wiring diagrams 1996 xjs
Ac fans run on after the ignition is in off position. LH runs at low speed while RH runs at high speed. Can anyone help with info or a link to wiring schematics?
Old Feb 21, 2019 | 02:47 PM
jimbov8's Avatar
Try jagrepair.com. Lots of free to download manuals available.
Old Feb 26, 2019 | 12:48 PM
louiedog's Avatar
Default jagrepair
Thank you, i'll see if they can help me.
Old Feb 26, 2019 | 12:53 PM
Jagboi64's Avatar
The high speed is probably the high speed relay sticking closed, and the low speed is the darlington transistor in the variable speed control circuit failing. Both items are inside the blower housing and require removal of the housings to get to them.
Old Feb 26, 2019 | 03:05 PM
warrjon's Avatar
Both failures will most likely be the darlington transistor, the one running fast the trans will be short and the one running slow the trans will be leaking.
Here is a circuit diagram I made when I repaired mine. You can repair it yourself. You will need a good soldering iron as the ground plane on the PCB is large and a small iron will struggle to melt the solder.
Challenger
Aug 9, 2015 04:30 PM
Razkid
Sep 29, 2013 08:37 AM
Bmxjeff
Oct 27, 2010 10:51 PM
ShadyJC
Jun 28, 2010 11:05 PM
m0t0rm0uth
General Tech Help
Jan 24, 2010 10:18 AM
