Air Problems in XJS 4.0
Old Aug 1, 2007 | 09:39 AM
XJ40ish's Avatar
Default RE: Air Problems in XJS 4.0
This is an XJ40 Forum, for XJ40's not XJS's ... a totally differnt model with completely different systems. You might want to try the techinal forums for non specific types. Geez.
Old Aug 1, 2007 | 10:14 AM
C'mon XJ.........You're a supermember and have been part of this forum for a while now. Scotts a new member and obviously still unsure as to whats what. Please cut the guy some slack and offer help if you can.
I have asked about opening an XJS section and await a reply.
Good luck with your enquiry scott, sorry I can't be more help
Jim
Old Aug 1, 2007 | 10:20 AM
Hey scott.......try this link. It will offer you lots of very useful info on your car. I'm not 100% sure if it will help with your current problem, but its somewhere to start.
Jim
http://www.jag-lovers.org/xj-s/book/XJS_help.zip
Old Aug 1, 2007 | 10:55 AM
Hey XJ...........XJS section added
Jim
Old Aug 1, 2007 | 12:57 PM
ken@britishparts.com's Avatar
Sounds like you have more than one problem.
Starting with the cold air on the feet: take off the passenger side (RH) center console cover. Do this by removing the vent and the trim piece will slide towards the engine and out. At the the top of the A/C unit you will see two identical electric motors. These control the vent flaps. Rap on them with the handle of a screw driver and see if causes the motors to kick in and flaps to change. You will need to replace these in time...big money for such a little motor.
Blowing cool but not cold: first, see what correcting the flaps does. You may have hot air mixing with the cold and killing the effect. Otherwise, you will need to throw some gauges on it and let us know what the pressures are. Without that info we are just shooting in the dark.
fast40driver
Apr 19, 2024 07:24 AM
johanasu
Sep 3, 2015 12:39 PM
David Mason
Sep 3, 2015 03:17 AM
Kristian_TT
Aug 28, 2015 02:32 AM
