Alternator not charging?
Old Jun 4, 2024 | 02:51 AM
paddyx350's Avatar
Default Alternator not charging?
Voltmeter always reads just over 13 volts when I start the car, then drops to 12.5 or so.
What can I do to see if the alternator is working/charging properly before I consider anything else?
Old Jun 4, 2024 | 04:45 AM
Greg in France's Avatar
A digital voltage reader in the cigar lighter socket should give you an accurate reading, eg:
Amazon Amazon
Old Jun 4, 2024 | 04:47 AM
ptjs1's Avatar
Paddyx350,
Measure the voltage with the engine running, directly at the battery terminals, and also at the bulkhead +ve & -ve terminals. Do not rely on a reading from the voltmeter. It's very often reading low.
Paul
Old Jun 6, 2024 | 05:13 AM
paddyx350's Avatar
So put a multi meter on the battery.
When its not running 12.8V, when it's running 14.04V.
Left it running for 10 mins and the voltage had dropped to from 14.04V to 13.93V
So is everything as it should be?
Old Jun 6, 2024 | 05:26 AM
100% OK
Old Jun 6, 2024 | 06:36 AM
ptjs1's Avatar
Your charging circuit seems fine, but, as expected, your voltmeter is reading low.
A clean up of the cluster connections and possibly running a separate earth can improve things.
Paul
ericeric7
Jan 9, 2026 01:46 PM
fatelvis
Sep 5, 2023 08:56 AM
Mantas Petrauskas
Nov 11, 2021 06:07 PM
Alster370
May 29, 2017 11:30 AM
