Angies Water Leak
Old Jun 30, 2012 | 05:51 PM
warrjon's Avatar
Originally Posted by Angie's v12
How do I know if the fan clutch is no good? I have 2 fans in the front of the car under the car under the hood. 1 runs constantly, the other I believe is for AC which I don't use and is shut off in the car so it doesn't spin. ( on the drivers side)
Based on this you need to replace the fan clutch as well.
Oil pressure will go down as the engine heats up this is due to the oil becoming more viscous as it walms.
Warm the engine up then turn the engine off and the fan should only rotate 2or 3 turns, mine used to turn 4or 5 times and I used to overheat in traffic, the car cooled down again once above 40km/h
Old Jul 1, 2012 | 10:17 AM
Angie's v12's Avatar
If its the fan (as you sit in the car) located on the passenger side mine spun a bit as well. The AC fan doesn't even work.
Old Jul 1, 2012 | 12:49 PM
Greg Edge's Avatar
A better description is on the right side. There are people from many countries here. Some are RH drive and some are LH drive. Left and right is always as you sit in the car.
Yes the fan clutch is on the right side. It is the mechanical fan run by the belt.
Old Jul 1, 2012 | 03:38 PM
Right side fan spun a bit, but I never overheat oil pressure just goes down to below 25.
Old Jul 1, 2012 | 05:32 PM
Greg Edge's Avatar
Oil pressure is below 25psi but the important part you forgot to tell us is at what engine rpm?
Old Jul 1, 2012 | 06:36 PM
Darel's Avatar
My oil pressure was down on the bottom of the scale at hot idle and a simple oil and filter change fxed that, probably 1/4 way up the gauge at hot ide now.
Old Jul 1, 2012 | 06:45 PM
Darel's Avatar
Also, where is the coolant gauge reading when the engine is warmed up fully? That electric fan should still be coming on when the engine is above a certain temp regardless of whether the AC is on or not.
Old Jul 1, 2012 | 07:51 PM
  #28
warrjon's Avatar
Sorry I should have been a little more specific, my bad,
The fan on the RH side driven by the engine belt has a viscous clutch, what the clutch does is vary the power to the fan. The clutch has a fluid in it that as it heats up provides more drive to the fan. If this does not work properly the car will over heat below 20-30km/h. Once you start driving faster the air flow through the front will keep the car cool.
Oil pressure in the V12 is very low at idle, my gauge sits almost at the bottom and as you rev past 1500rpm the gauge will move up. This is normal. Can you post what numbers the gauge pointer are on at idle and 2000rpm.
Old Jul 2, 2012 | 11:35 PM
50 on oil at idle(when cold), when I'm driving and warmed up and at a stop light it's between 0 & 25 ( say like 12). At 2000 rpm it's about 40
Old Jul 3, 2012 | 01:26 AM
  #30
Greg in France's Avatar
The engine is 100% normal for oil pressure, then. Nothing to worry about.
Greg
Old Jul 3, 2012 | 06:34 AM
  #31
warrjon's Avatar
Yep agreed
Pressure is not the most important part FLOW is, like a garden hose if you put your finger over the end the pressure goes up but the flow will decrease. The V12 flow oil very well but the pressure is lower than most cars. This is OK.
Old Jul 3, 2012 | 04:35 PM
  #32
I can't thank you guys enough. I feel soo much better now. I was told it was common in the V12's. Now just to get the stupid coolant leak found and fixed and I'll have no problems with her. (knock on wood) lol
Old Jul 4, 2012 | 04:15 AM
  #33
warrjon's Avatar
Good luck
Old Jul 4, 2012 | 11:35 PM
  #34
Mechanic at 8am... Happy 4th my jaguar friends!!!
Be safe and have fun!!!
Old Jul 6, 2012 | 09:16 PM
  #35
OK... Diana's rad is leaking from underneath, so I have to have that fixed. My mechanic is sending it out to be repaired, we're looking for a rad now because I don't want a crappy aftermarket radiator. I'm so sad right now!! This is the biggest job my baby has ever needed. I've only had to replace lines for her. Now she's having an "operation".
Old Jul 6, 2012 | 09:28 PM
  #36
nosox's Avatar
When my girl needs an "operation" big or small, I always stroke her flying buttress and tell her it'll be ok
Good luck with the op
Old Jul 6, 2012 | 09:38 PM
  #37
Unhappy
I'm absolutely heartbroken right now. I knew there was a problem, but geez... My poor baby. Lol I'm seriously ill over this. This is my CAR it's like one of my kids!!
Old Jul 6, 2012 | 09:57 PM
  #38
M90power's Avatar
our V12 have solid lifter valvetrains, so theres no need for any more oil pressure than that.
Old Jul 7, 2012 | 08:14 PM
  #39
Greg Edge's Avatar
There are no lifters in this engine.
Old Jul 8, 2012 | 12:07 PM
  #40
What are lifters? Now I'm really confused. Also, my rad is being sent out for repair because we can't locate one for my car... So I'm really angry!
