Antenna Ground Wire (Black)
Old Apr 12, 2019 | 05:39 PM
Maverick6532's Avatar
Default Antenna Ground Wire (Black)
Where do you plug the ground antenna wire into?
Old Apr 12, 2019 | 05:42 PM
On a 1996 XJS
Old Apr 17, 2019 | 12:54 PM
Anglicomarine0326's Avatar
There should be a small port near the aerial mast to plug into. I believe you have a German made Hirschmann Antenna motor unit, but the Japanese made ones are similar.
Old Apr 18, 2019 | 09:06 AM
It’s not the end towards the rear of the car it’s the end in the front I’ve been told it plugs into the back of the radio but I don’t want to take the whole radio out if I don’t have to.
Old Apr 18, 2019 | 09:13 AM
Any wire at the back of the radio, power, ground, and antenna are only accessible by taking out the radio. I believe that the oem radio had a harness of these wires, as well as speaker connections. If you're uncertain or intimidated by removing the radio from the dashboard, any competent audio technician can easily do it.
srpope80
Oct 2, 2018 05:27 PM
RJag
Nov 2, 2015 07:37 AM
Lufferman
Apr 2, 2015 11:30 PM
daro31
Jan 1, 2015 11:42 AM
ArmyJag
XJ40 ( XJ81 )
Jan 5, 2009 11:17 PM
