Anybody ever convert auto to manual trans?
Old Jan 16, 2009 | 10:16 AM
JagtechOhio's Avatar
Default RE: Anybody ever convert auto to manual trans?
Excellent overview from a man who knows his craft, thanks for that.
Two additional points:
Do you agree that that stiff suspension on a convertible variant, particularly a pre-facelift car, amplifies the lack of chassis rigidity and can actually be a detriment re: increased cowl shake?
Are you still looking for pedal boxes? If so, please get in touch.
Old Jun 2, 2010 | 11:02 PM
moto250cr's Avatar
Default manual transmission XJS
Wow, I wish I would have seen this post when it was going around the first time. I have owned 3 XJS convertibles. A 1995 6 cyl automatic, a 1993 6 cyl 5 speed and a 1990 V12 automatic. I owned the 93 and the 95 at the same time and took them out for a race to see the difference. At the end of a quarter mile my 5 speed car was about 10 car lengths ahead of the automatic. There is no comparison. The manual was so much faster and so much more fun to drive. I have actually put a 350 chevy 6 speed in it now after I tore up the 5 speed and couldn't get parts. Well, I could if I wanted to spend $3500. My choice was a little more money but 425 horsepower makes it worth it.
Old Jan 2, 2012 | 08:12 PM
calvindoesntknow's Avatar
hey guys, im converting mine to a manual, partly because you cant drift an automatic ( someones gonna yell at me on here for drifting an xjs ) and two because im doing the custom metal work to make the lister rear flares on the back and who would want to run 295 rear tires behind a v12 with an automatic. realllly
Old Jan 3, 2012 | 11:25 AM
Mish_Mish's Avatar
More details please, parts used, budget and such.
Thanks!
Old Jan 3, 2012 | 06:36 PM
ronbros's Avatar
question, driven mans garage looks famlier,DUH, check mine out also.
question, how many of you guys have actually driven a V12 Jaguar, WITH A MANUAL TRANSMISSION, 4-5-6??.
well i HAVE and as i said in other posts, if i were to to a build again YES, it would be a manual trans , stick shift.haha.
and if you came to a full stop,shut the engine off,, put in 4th gear, clutch out, turn the key , and the car would pickup smoothly and drive perfect, NO buckin, jumpin, or roughness. great for new drivers!
and just maybe Driven man is incarcerated, with not much to do, anybody??
Old Jan 4, 2012 | 09:24 PM
i did it for about 3$ maybe 35$ because i bought nice stuff, its not that dificult if you can fabricate a transmission mount and clutch pedal, and misc other stuff.
Old Jan 5, 2012 | 06:23 PM
  #28
ronbros's Avatar
i think calvindoesntknow is right, he can do it for $3. or with good stuff $35.
sure knows how to save money! DUH
Old Jan 6, 2012 | 11:14 AM
yeah, im at school at the moment but ill post some pics and such when im home. but factor in the flywheel, clutch plate, pressure plate, buy a used or blown mustang t5 and swap the heavy duty gm t5 gears, ( sounds difficult but really isnt) get a used camaro driveshaft (25$ and get it shortened ) slip yolk, for the clutch pedal, you can buy one that fits with a little grinding for like 350 on ebay, or you can be like me and copy his pattern from the pictures and make your own, 3.5 inch clutch throw . then get a pilot bearing from the driven man or have a bushing to fit it made it. if you use the chevy ford adapter bearing you can fit the stock ford t5 on, which the mustang cobra is about 1100$ rebuilt and holds 415 hp. use the www.fivespeeds.com bellhousing. fabricate the mount out of metal from a local hardwear store. if ou price it out it isnt that bad, it just takes much more than 25 hours to make. Espcially if youre like me and you like to get carried away. any questions just ask
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Aus V8S
Nov 13, 2015 11:01 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
pnwrs2000
Sep 3, 2015 11:55 AM
