Automatic Off Headlights
Old Mar 12, 2023 | 02:38 PM
Patrick 1989 XJS's Avatar
Default Automatic Off Headlights
My warning buzzer does not indicate if the dashboard or headlights have been left on. I have killed my battery a couple of times. I am going to install a relay that automatically turns off all of the lights. Has anyone installed an auto off relay system? Any ideas? If I design something I will post the wiring diagram.
Old Mar 12, 2023 | 03:07 PM
Doug's Avatar
Should be a fun project. Have not seen it done before.
FWIW
A "Headlights On" warning buzzer is very easy to install. Surely a lot easier than an auto-off system, I'd think
Old Mar 17, 2023 | 02:36 PM
Doug,
Was there originally a warning buzzer if the light were left on after the ignition key was removed? The seat belt buzzer unit has several contact point. Was this buzzer used as a warning device for other issues?
I am out of town and don't have the car to look at and test. There are two wires separate from the key ignition power wiring. Are these the wires that close the signaling relay when the key is inserted in the ignition?
Toonza
May 10, 2025 03:03 AM
Axxel
Sep 28, 2020 07:33 AM
StevieYonder
Mar 28, 2019 04:13 PM
rwcmick
Nov 7, 2013 07:02 AM
