Battery or Alternator?
Old Aug 8, 2018 | 11:59 AM
catterwaller's Avatar
If the alternator check out good and the belt and wiring are ok, Look at the damper pulley on the front of the crankshaft. A common problem is the rubber pulley mounting goes bad so the pulley slips on the damper. Symptoms are very much like a loose alternator belt. Easy to tell. Mark a line on the pulley and damper with chalk, paint marker or silver sharpie. Go for a run and check to see if the marks are still in line.
Booty1313
Dec 23, 2012 12:43 AM
thuffner3
May 27, 2011 10:06 PM
Willchill
Jan 18, 2011 08:39 PM
BrightonRay
Nov 30, 2009 12:20 PM
riemann
XJ40 ( XJ81 )
Oct 3, 2008 10:05 PM
