Battery Dies
Old Feb 19, 2009 | 08:04 PM
sodium's Avatar
Default Battery Dies
OK, here's a weird one. Sometimes the battery is drained, sometimes it's not. I replaced the battery and 2 days later it's completely flat.
I'm gonna start running down wiring with a clamp on amp meter for lack of a better idea. Anyone got a "check this first" for this?
95 XJS 4.0 Convertible.
Thanks,
-Sodium
Old Feb 19, 2009 | 09:51 PM
JagtechOhio's Avatar
Power antenna
Old Feb 20, 2009 | 06:35 AM
sodium's Avatar
Thanks. I'll check that out.
Old Feb 20, 2009 | 03:04 PM
mrdobsie's Avatar
If its not the Power Arial you could Try Pulling fuses 1 at a time and then removing one battery lead..If the battery lead flashes strongly when you contact it with the battery the drain fault is still apparent. Once you have found the faulty circuit after removing the correct fuse the battery lead will not flash on contact..Ensure you have the car outdoors when trying this as some old batteries can leak a gas which in rare circumstances can ignite.
99xk8guy
May 28, 2024 09:36 PM
Malihide
Apr 2, 2016 04:05 PM
concernedowner123
Sep 24, 2015 08:49 PM
