Bonnet Insulation retaining bar
Old Jul 14, 2023 | 05:43 AM
JJS- Florida's Avatar
Default Bonnet Insulation retaining bar
Good morning, all!
Today's project consists of repairing a bar that crosses under the bonnet and holds the insulation in place. This bar has apparently come loose previously,and the (sketchy) paperwork indicates it was repaired with a tack weld (which I cannot see at a fast glance).... My thought was to simply drill a small hole and secure strap/bar with a rivet? Suggestions welcome, but I do not have handy access to a welder...
Thanks!!
Old Jul 14, 2023 | 07:18 AM
Robbo D's Avatar
My bar is pop riveted on and looks like it was that way from the factory.
Old Jul 14, 2023 | 07:57 AM
Greg in France's Avatar
Yes, pop rivetted in my case too. Mind you, if you are not a purist, I recommend removing the OEM blanket and replacing it with this stuff, or similar:
https://www.silentcoat.co.uk/collections/silent-coat
It is very effective as a bonnet (hood) liner and far thinner than the OEM, thus you get better air flow over the engine and lower engine bay temps. Then you can do away with the metal strut.
Old Jul 14, 2023 | 12:03 PM
mikebaker3's Avatar
Mine has a 1/8" pop rivet on both ends.
roger.neill
22
Nov 12, 2022 04:28 PM
jonzyjones11
Feb 15, 2022 07:11 PM
ericisback
E type ( XK-E )
Nov 22, 2021 01:35 PM
JPG
Sep 23, 2014 08:58 PM
scottg09
May 22, 2013 02:53 PM
