Boot underside vents 90 XJS Conv. 5.3
Old Jan 14, 2021 | 06:18 PM
mikebaker3's Avatar
Default Boot underside vents 90 XJS Conv. 5.3
I went through my reprint of the factory parts catalogue but was unable to find a part number for the four vents that drain the boot at the front on the boot floor. Anyone have a part number. Here are photos of the rubber vents.
Old Jan 15, 2021 | 10:57 PM
92/93 XJS's Avatar
I just dealt with the same issue. No part # and no help at dealer. So, recalling my youth and drilling holes thru firewalls for various reasons, I found at my local NAPA store acceptable rubber plugs that fit perfectly. They are simply round, not the square shape of the OEM plugs, but do the job nicely.
Good luck, David
Old Jan 16, 2021 | 09:34 AM
malc4d's Avatar
I have the same problem with the battery exhaust pipe grommet. It has also split. I cant find the right one either....
Old Jan 16, 2021 | 05:37 PM
equiprx's Avatar
.I have a set from a 1994.
They have short right angle tubes not the trapezoid.
I think they are improved from the 90's design
The tubes are less likely to let water back up the spout.
Contact me with text or call to 650-455-1110 if you want them.
Measure the body hole size so we know we are talking about compatibility.
I don't visit the forums as often as I used to.
Steve
worzella
Sep 3, 2019 05:43 AM
TexasTraveler
Jul 27, 2019 11:42 AM
Crackerbuzz
Jul 5, 2019 07:00 AM
spielnicht
Sep 6, 2012 07:59 AM
markman
Mar 27, 2012 01:59 PM
