Both sides power windows stopped workin
Old Apr 27, 2024 | 07:57 PM
Luis Tomas's Avatar
Default Both sides power windows stopped workin
I have a 1988 Jaguar XJS and none of the small windows go up, so I uncovered the cover where the motor is that helps them go up and it only makes the sound but they don't go up. You have to put some liquid in it or you have to do something specific, it seems there is power because the switch only makes the motor sound
Old Apr 29, 2024 | 06:28 AM
wardhill68's Avatar
Im chasing the same problem . The picture you provided is for the convertible top motor. The motors for the small window are near each window. Therebare relays and thermal breakers for the windows back there by the roof motor.
Old Apr 29, 2024 | 06:41 AM
ptjs1's Avatar
I think you perhaps have an H&E conversion rather than the later factory convertible?
So it might be different, but on the factory convertible, you have to press the Roof switch Up for 8 seconds before the windows will.start to rise.
Paul
Old Apr 29, 2024 | 08:11 AM
malc4d's Avatar
Just a small point... the windows are electric, Only the roof is hydraulicly driven.
Old May 6, 2024 | 10:58 AM
Luis Tomas's Avatar
Well, I bought it by lowering the manual top, so first I started one glass that wouldn't lower and now it's both. Where could I find the fuses or something?
Old May 6, 2024 | 10:59 AM
Luis Tomas's Avatar
The windows go up and down electrically and the top is manual.Is that engine in the photo for a hood?
Old May 6, 2024 | 05:45 PM
ptjs1's Avatar
The main item in your photo is the pump to operate the hood.
As you can see, you, or someone else, have turned the valve to the "Manual" position. That means that the hood will not go up and down when you you press the hood switch.
You need to turn the valve back to the "Electric" position and then see if the hood works properly with the windows when the switch is pressed.
Paul
malc4d
Nov 26, 2018 12:47 AM
Gilly39
Sep 28, 2017 04:08 AM
XJ-Executive
Nov 15, 2016 12:54 PM
Some Day, Some Day
Sep 11, 2016 02:35 PM
