brake bleeding sequence
Old Aug 14, 2022 | 08:05 AM
J_C_R's Avatar
Default brake bleeding sequence
I've received my rebuilt master cylinder and have bench bled it.
From various sources I see that some people think the sequence of bleeding the brakes is very important, while others don't.
I don't have a repair manual. So...is there a recommended sequence?
1987 XJ-S V12, with inboard rear brakes
Thanks!
John
Old Aug 14, 2022 | 08:34 AM
jal1234's Avatar
Usually start with the furthest from the master cylinder on whatever end you start with. Doesn't matter front or rear since they are separate circuits from each other. Suck as much old fluid as you can out of the reservoir before adding fresh, and bleed long enough to get fresh, clean fluid at each caliper.
Old Aug 14, 2022 | 10:51 AM
mghirsch's Avatar
I can't remember if the 87 had ABS. If it doesn't, follow Jal's advice, if it has ABS, look up the procedure, it is not the usual one.
Old Aug 14, 2022 | 03:02 PM
jal1234's Avatar
No ABS in 1987.
Old Aug 14, 2022 | 03:28 PM
ptjs1's Avatar
ABS was introduced mid-87 but John's car doesn't have it. The giveaway is that he's referred to buying a "Master Cylinder", hence pre-ABS.
Paul
Old Aug 15, 2022 | 06:40 AM
J_C_R's Avatar
Correct, I do not have ABS.
Thanks guys,
John
rsinor
E type ( XK-E )
Jul 22, 2022 10:08 AM
Palindrome
Mark V - X 420G
Oct 1, 2017 02:17 PM
diamond_tom
Apr 5, 2014 02:41 PM
heavyrunner
Mar 19, 2014 10:25 AM
