Brake booster vacuum tank
Old Jun 6, 2016 | 03:46 PM
BC XJS's Avatar
The ecu uses direct feed to the engine. The brake booster is on a separate circuit that has a check valve that holds highest vacuum because engine vacuum fluctuates as your engine speed and load change
Old Jun 7, 2016 | 04:02 AM
plums's Avatar
Originally Posted by Doug
They did? No, I didn't know. Which models? Was it some sort of separate chamber or ?
It's in the booster itself. There is reserve valving. You don't
use up all the vacuum on any particular stop.
Remember being able to pump the brake pedal 4 or 5 times before
getting a hard pedal when the ignition was off?
If you still have a 1973 F-body manual the description should be
in there. Failing that, a 1968 Ford manual.
Old Jun 7, 2016 | 05:47 AM
Greg in France's Avatar
Plums
Apologies if you knew this, but the Lockheed vacuum servo on the XJS has that feature, as AFAIK, do all such Lockheed servos on all UK cars of the era. The XJS extra reservoir is in addition to that provided by the Lockheed unit itself.
Greg
Old Jun 7, 2016 | 07:07 AM
Doug's Avatar
Thanks.
Yes, I was aware of there being a 'reserve capacity', so to speak, to the brake booster.
Earlier I thought you were referring to some sort of separate reserve storage.
Paul_59
Apr 3, 2016 04:55 AM
Iceman1
Apr 1, 2016 06:52 PM
Ipc838
Apr 1, 2016 10:31 AM
Tangomike7073
Mar 28, 2016 04:35 AM
Uncle Fishbits
Mar 24, 2016 06:20 PM
