Brake master cylinder
Old Aug 5, 2023 | 08:28 AM
AndreasXJS's Avatar
Default Brake master cylinder
Another question: is the brake master cylinder (for 96 4.0L) available new at a reasonable price? Or does anyone know if there are identical parts? It's quite conceivable that this is not a one-off for Jaguar, but was also fitted to models from other manufacturers.
Thanks for help!
Andreas
Old Aug 5, 2023 | 09:00 AM
Doug's Avatar
The same master cylinder was used on the X300 sedans and possible other Jags.
I don't know if it was used on other makes
Assuming LHD the part number is JLM12080. Google "JLM12080 Jaguar" and see what comes up!
Here in the USA there are companies that rebuild master cylinders. I just have to believe that such companies exist in Europe. This can be a good alternative or, in some cases, the only alternative
Old Aug 5, 2023 | 09:38 AM
ptjs1's Avatar
Andrea's,
Still available from Jaguar but big money as I'm sure you've found out. The majir indeoendents Barratts, Manners etc dont seem to sell a pattern replacement.
Good luck
Paul
yarpos
Apr 1, 2023 04:43 PM
falderfer
E type ( XK-E )
May 21, 2021 11:53 AM
my420
Apr 23, 2021 11:18 AM
Tasng4
Mark V - X 420G
Jul 1, 2019 05:04 AM
prodigy215
20
Nov 2, 2011 12:34 PM
