Brakes hitting the floor
Old Jul 5, 2011 | 06:14 AM
Leatherman007's Avatar
No success. The accumulator pump filled the accumulator. I pumped the brake pedal 75 times, still no hard pedal. The reservoir is full.
Old Jul 5, 2011 | 06:15 AM
warrjon's Avatar
Originally Posted by Leatherman007
The accumulator pump starts and runs for some time and then stops. I tried pumping the pedal after the accumulator was filled. Still no hard pedal. I will try again. The car is level. Will report back in 10 minutes.
Pumping the pedal with the ignition OFF purges the accumulator of brake fluid. The pedal should go hard when the fluid is drained.
Then turn the ignition ON wait till the pump stops then pump the pedal again several times this will prime the system and the reservoir level should drop.
Old Jul 5, 2011 | 06:25 AM
Do I understand the procedure is:
1 ignition off
2 pump brake pedal to empty the accumulator
3 turn ignition on
4 wait for accumulator pump to stop
5 keep ignition on
6 pump the brake pedal
Is this correct?
Old Jul 5, 2011 | 06:30 AM
warrjon's Avatar
1 ignition off
3 turn ignition on
5 keep ignition on
Is this correct?
You can skip 1 and 2 - EDIT forgot to say that the point here is if this does not happen and the pedal never goes hard you may need to investigate the possibility of an ABS issue. It might be worth investing a ROM.
Go straight to 3,4,5, and 6 Pump pedal until pump stops - This procedure primes the ABS.
Then bleed brakes.
Old Jul 5, 2011 | 06:40 AM
Will continue in daylight and report back. Time in California is 4:40 AM July 5th 2011. Thanks for your advice.
Old Jul 5, 2011 | 06:42 AM
warrjon's Avatar
And I thought I was a Jag nut you should be asleep - which is where I am going good luck and keep us posted
cheers WJ
H20boy
Dec 24, 2024 03:23 PM
Razor
Aug 28, 2019 08:34 PM
PMKimpton
Aug 3, 2019 08:22 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
