A/C amp
Old Mar 13, 2014 | 08:01 AM
JTsmks's Avatar
Default A/C amp
My amps been on the fritz for some time and now my vents are stuck on defrost. Is the a way to manipulate the servo to put it on center vent and leave it there? Thanks
Old Mar 13, 2014 | 08:43 AM
Doug's Avatar
The climate control amp for the older Delanair Mark II system, right? Pre 1987-ish?
Unplug the amp from the harness. It's a round connector. Locate the pins of the red and purple wires.
Using jumper wires you'll apply 12v "+" to one of the wires and apply ground to the other. The servo will rotate in one direction. Reversing polarity will rotate the servo motor in the other direction. I can't remember for sure which direction you'll have to go to take it off defrost and into cooling or blend mode. I think purple wire "+" will do it.
Do not over-rotate the motor or you'll break the little switches as the cams rotate. Go in small steps.
jluckcuck
Nov 6, 2015 07:49 AM
dan102877
Sep 29, 2015 06:47 PM
oldjaglover
Sep 29, 2015 03:27 PM
Rocky15
Sep 28, 2015 04:59 PM
