a/c comp wont shut off
Old Jul 31, 2012 | 11:33 AM
steve's Avatar
Default a/c comp wont shut off
HI 85 xjs comp wont cycle the ranco stat inside cycles but green wire stays powered on , disconnected servo it cycles tryed two nos servos comp still no cycle ??????
Old Jul 31, 2012 | 11:52 AM
sidescrollin's Avatar
can you reiterated a bit?
So are you saying that everything inside is working but the a/c comp doesn't come online?
Have you checked the wiring and fuses for the compressor?
when i first got to looking at my a/c all the wires were worn or disconnected at the compressor.
Old Jul 31, 2012 | 12:56 PM
Doug's Avatar
Any sign of wiring changes?
Do you have a schematic?
Old Jul 31, 2012 | 02:19 PM
steve's Avatar
Default ac
the a/c works have done more testing the comp cycles from 72deg up to 85 but 72 down to 65 it runs constant there is a micro switch or the servo that is causing it to run constant
Old Jul 31, 2012 | 06:16 PM
Doug's Avatar
Can't figure out what you're saying. Are you asking something or stating something?
Punctuation please ! :-)
Last edited by Doug; Jul 31, 2012 at 06:41 PM. Reason: Had to edit my OWN post to make it understandable :-)
Old Jul 31, 2012 | 06:22 PM
steve's Avatar
Default ac
the micro switch on the servo is not letting the ranco stat cycle the comp when in max a/c this is not normal may just buy pass switch if poss steve
Old Jul 31, 2012 | 06:43 PM
Doug's Avatar
Later tonight I'll look at the diagrams and try to help. But is the evap core icing up?
To the best of my knowledge the Ranco won't do anything unless the evap core ices.
mikiep
Dec 20, 2019 07:37 PM
dan102877
Sep 29, 2015 06:47 PM
oldjaglover
Sep 29, 2015 03:27 PM
42Ajd
Sep 26, 2015 07:04 PM
